查看: 769|回复: 0
[Windows] Not found the kernel library or the kernel library is invalid
发表于 2023-5-28 04:24 | 显示全部楼层 |阅读模式
如果你在使用某些软件时,遇到这样的提示:
Not found the kernel library or the kernel library is invalid or the kernel library of this edition does not support DLL!
解决方法是: https://wwsy.lanzouf.com/iZChx0w7vweh
下载,解压后将内含的文件复制到应用目录下即可。
顺便说一下,我下载的速度稳定在3M/S,真不错!
GMT+8, 2026-2-4 17:37 , Processed in 0.048016 second(s), 27 queries .
