查看: 881|回复: 0
[表格(xls)] 表格拆分 表格按部门拆分 表格拆分成多个sheet VBA代码
发表于 2020-11-13 16:52 | 显示全部楼层 |阅读模式
注意:把待拆分工作表名称 改成 “数据源
看图:
代码:
[Visual Basic] 纯文本查看 复制代码
Sub fb()
    Dim myRange As Variant
    Dim myArray
    Dim titleRange As Range
    Dim title As String
    Dim columnNum As Integer
    myRange = Application.InputBox(prompt:="请选择标题行:", Type:=8)
    myArray = WorksheetFunction.Transpose(myRange)
    Set titleRange = Application.InputBox(prompt:="请选择拆分的表头,必须是第一行,且为一个单元格,如:“姓名”", Type:=8)
    title = titleRange.Value
    columnNum = titleRange.Column
    Application.ScreenUpdating = False
    Application.DisplayAlerts = False
    Dim i&, Myr&, Arr, num&
    Dim d, k
    For i = Sheets.Count To 1 Step -1
        If Sheets(i).Name <> "数据源" Then
            Sheets(i).Delete
        End If
    Next i
    Set d = CreateObject("Scripting.Dictionary")
    Myr = Worksheets("数据源").UsedRange.Rows.Count
    Arr = Worksheets("数据源").Range(Cells(2, columnNum), Cells(Myr, columnNum))
    For i = 1 To UBound(Arr)
        d(Arr(i, 1)) = ""
    Next
    k = d.keys
    For i = 0 To UBound(k)
        Set conn = CreateObject("adodb.connection")
        conn.Open "provider=microsoft.jet.oledb.4.0;extended properties=excel 8.0;data source=" & ThisWorkbook.FullName
        Sql = "select * from [数据源$] where " & title & " = '" & k(i) & "'"
        Worksheets.Add after:=Sheets(Sheets.Count)
        With ActiveSheet
            .Name = k(i)
            For num = 1 To UBound(myArray)
                .Cells(1, num) = myArray(num, 1)
            Next num
            .Range("A2").CopyFromRecordset conn.Execute(Sql)
        End With
        Sheets(1).Select
        Sheets(1).Cells.Select
        Selection.Copy
        Worksheets(Sheets.Count).Activate
        ActiveSheet.Cells.Select
        Selection.PasteSpecial Paste:=xlPasteFormats, Operation:=xlNone, _
                               SkipBlanks:=False, Transpose:=False
        Application.CutCopyMode = False
    Next i
    conn.Close
    Set conn = Nothing
    Application.DisplayAlerts = True
    Application.ScreenUpdating = True
End Sub
GMT+8, 2026-2-4 19:23 , Processed in 0.044644 second(s), 34 queries .
