查看: 1177|回复: 0
忘了数据库密码怎么办?Navicat 有链接就好!
发表于 2024-1-7 01:22 | 显示全部楼层 |阅读模式
最近工作中遇到这么一个事情就是 忘了数据库root的密码!
以下是我在某度中找到找回密码的方式
1.Navicat ->文件->导出链接  (记得要导出密码)
2.打开 配置php环境 写个php文件 粘贴以下代码  记得将密文的密码替换掉哦
<?php
namespace FatSmallTools;
class NavicatPassword
    protected $version = 0;
    protected $aesKey = 'libcckeylibcckey';
    protected $aesIv = 'libcciv libcciv ';
    protected $blowString = '3DC5CA39';
    protected $blowKey = null;
    protected $blowIv = null;
    public function __construct($version = 12)
        $this->version = $version;
        $this->blowKey = sha1('3DC5CA39', true);
        $this->blowIv = hex2bin('d9c7c3c8870d64bd');
    public function encrypt($string)
        $result = FALSE;
        switch ($this->version) {
            case 11:
                $result = $this->encryptEleven($string);
                break;
            case 12:
                $result = $this->encryptTwelve($string);
                break;
            default:
                break;
        return $result;
    protected function encryptEleven($string)
        $round = intval(floor(strlen($string) / 8));
        $leftLength = strlen($string) % 8;
        $result = '';
        $currentVector = $this->blowIv;
        for ($i = 0; $i < $round; $i++) {
            $temp = $this->encryptBlock($this->xorBytes(substr($string, 8 * $i, 8), $currentVector));
            $currentVector = $this->xorBytes($currentVector, $temp);
            $result .= $temp;
        if ($leftLength) {
            $currentVector = $this->encryptBlock($currentVector);
            $result .= $this->xorBytes(substr($string, 8 * $i, $leftLength), $currentVector);
        return strtoupper(bin2hex($result));
    protected function encryptBlock($block)
        return openssl_encrypt($block, 'BF-ECB', $this->blowKey, OPENSSL_RAW_DATA|OPENSSL_NO_PADDING);
    protected function decryptBlock($block)
        return openssl_decrypt($block, 'BF-ECB', $this->blowKey, OPENSSL_RAW_DATA|OPENSSL_NO_PADDING);
    protected function xorBytes($str1, $str2)
        $result = '';
        for ($i = 0; $i < strlen($str1); $i++) {
            $result .= chr(ord($str1[$i]) ^ ord($str2[$i]));
        return $result;
    protected function encryptTwelve($string)
        $result = openssl_encrypt($string, 'AES-128-CBC', $this->aesKey, OPENSSL_RAW_DATA, $this->aesIv);
    public function decrypt($string)
        $result = FALSE;
            case 11:
                $result = $this->decryptEleven($string);
                break;
            case 12:
                $result = $this->decryptTwelve($string);
                break;
            default:
                break;
        return $result;
    protected function decryptEleven($upperString)
        $string = hex2bin(strtolower($upperString));
        $result = '';
            $encryptedBlock = substr($string, 8 * $i, 8);
            $temp = $this->xorBytes($this->decryptBlock($encryptedBlock), $currentVector);
            $currentVector = $this->xorBytes($currentVector, $encryptedBlock);
            $result .= $temp;
        if ($leftLength) {
        return $result;
    protected function decryptTwelve($upperString)
        return openssl_decrypt($string, 'AES-128-CBC', $this->aesKey, OPENSSL_RAW_DATA, $this->aesIv);
use FatSmallTools\NavicatPassword;
//需要指定版本,11 或 12,12 以上用 12,以下用 11
$navicatPassword = new NavicatPassword(12);
//$navicatPassword = new NavicatPassword(11);
//解密
$decode = $navicatPassword->decrypt('你的密文密码');
echo $decode."\n";
3.运行
明文密码就解析出来啦!
以上代码是百度出来的 仅为了在繁忙的工作中能快捷的找回数据库链接密码!
当然时间充足的大佬可以自己写个解密的function来处理!
GMT+8, 2026-2-4 16:03 , Processed in 0.056547 second(s), 27 queries .
