查看: 728|回复: 0
[经验技巧] 客户机操作系统已禁用 CPU。请关闭或重置虚拟机。
发表于 2024-2-21 09:50 | 显示全部楼层 |阅读模式
异常:客户机操作系统已禁用 CPU。请关闭或重置虚拟机。 这是AMD电脑(机械革命Code01 V2.0)的VMware安装macOS 最后出现的错误我们需要在虚拟机运行之前打开虚拟机安装目录自动生成的macOS xxxx(你选择安装的版本号).vmx只需要在末尾添加
smc.version = "0"cpuid.0.eax = "0000:0000:0000:0000:0000:0000:0000:1011"cpuid.0.ebx = "0111:0101:0110:1110:0110:0101:0100:0111"cpuid.0.ecx = "0110:1100:0110:0101:0111:0100:0110:1110"cpuid.0.edx = "0100:1001:0110:0101:0110:1110:0110:1001"cpuid.1.eax = "0000:0000:0000:0001:0000:0110:0111:0001"cpuid.1.ebx = "0000:0010:0000:0001:0000:1000:0000:0000"cpuid.1.ecx = "1000:0010:1001:1000:0010:0010:0000:0011"cpuid.1.edx = "0000:0111:1000:1011:1111:1011:1111:1111"smbios.reflectHost = "TRUE"hw.model = "MacBookPro14,3"board-id = "Mac-551B86E5744E2388"keyboard.vusb.enable = "TRUE"mouse.vusb.enable = "TRUE"
提示未能启动虚拟机
将vmx文件中 virtualHW.version = "19" 的值改为"16"(如果本身就是16,则将值改为10试试)
GMT+8, 2026-2-4 19:29 , Processed in 0.033007 second(s), 27 queries .
