查看: 1129|回复: 0
安装linux下mysql
发表于 2024-6-13 17:49 | 显示全部楼层 |阅读模式
初始化:
        mysqld --initialize --console
设置权限:
        chown -R mysql:mysql /var/lib/mysql
启动服务:
        systemctl start mysqld
查看临时密码:
        cat /var/log/mysqld.log |grep localhost
更改Mysql登录密码:
         alter user 'root'@'localhost' identified by '123456';
查询在哪:
        whereis mysql
安装步骤:
rpm -ivh mysql-community-common-8.0.28-1.el7.x86_64.rpm
rpm -ivh mysql-community-client-plugins-8.0.28-1.el7.x86_64.rpm
rpm -ivh mysql-community-libs-8.0.28-1.el7.x86_64.rpm
rpm -ivh mysql-community-client-8.0.28-1.el7.x86_64.rpm
rpm -ivh mysql-community-icu-data-files-8.0.28-1.el7.x86_64.rpm
rpm -ivh mysql-community-server-8.0.28-1.el7.x86_64.rpm
检查是否 有:
rpm -qa|grep mariadb
有:rpm -e --nodeps mariadb-libs
GMT+8, 2026-2-4 16:13 , Processed in 0.033702 second(s), 27 queries .
