查看: 674|回复: 1
[Windows] 为Win10以上系统桌面增加一键显示隐藏系统文件及扩展名
发表于 2025-3-22 12:26 | 显示全部楼层 |阅读模式
把以下内容复制到记事本当中,并保存为.cmd或.bat的批处理文件,双击运行此处理文件即可添加成功.
@Echo Off
Title 右键添加隐藏/显示文件及扩展名工具 & Color 0A
cd %systemroot%\system32
call :IsAdmin
set HideFileExt=%WINDIR%\SYSTEM32\HideFileExt.vbs
echo Dim WSHShell>%HideFileExt%
echo Set WSHShell = WScript.CreateObject("WScript.Shell")>>%HideFileExt%
echo. >>%HideFileExt%
echo ' 读取当前隐藏状态>>%HideFileExt%
echo If WSHShell.RegRead("HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Hidden") = 1 Then>>%HideFileExt%
echo     ' 若当前显示隐藏文件,则设置为隐藏>>%HideFileExt%
echo     WSHShell.RegWrite "HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Hidden", 2, "REG_DWORD">>%HideFileExt%
echo     WSHShell.RegWrite "HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced\HideFileExt", 1, "REG_DWORD">>%HideFileExt%
echo     WSHShell.RegWrite "HKCR\Directory\Background\shell\HideFileExt\MuiVerb","显示文件及扩展名","REG_EXPAND_SZ">>%HideFileExt%
echo     WSHShell.Popup "已隐藏系统文件和扩展名", 1, "操作成功", vbInformation>>%HideFileExt%
echo Else>>%HideFileExt%
echo     ' 若当前隐藏文件,则设置为显示>>%HideFileExt%
echo     WSHShell.RegWrite "HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced\Hidden", 1, "REG_DWORD">>%HideFileExt%
echo     WSHShell.RegWrite "HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced\HideFileExt", 0, "REG_DWORD">>%HideFileExt%
echo     WSHShell.RegWrite "HKCR\Directory\Background\shell\HideFileExt\MuiVerb","隐藏文件及扩展名","REG_EXPAND_SZ">>%HideFileExt%
echo     WSHShell.Popup "已显示系统文件和扩展名", 1, "操作成功", vbInformation>>%HideFileExt%
echo End If>>%HideFileExt%
echo ' 刷新资源管理器>>%HideFileExt%
echo WSHShell.SendKeys "{F5}">>%HideFileExt%
echo Set WSHShell = Nothing>>%HideFileExt%
Reg add "HKCR\Directory\Background\shell\HideFileExt" /v "MuiVerb" /t REG_SZ /d "隐藏文件及扩展名" /f
Reg add "HKCR\Directory\Background\shell\HideFileExt" /v "Icon" /t REG_EXPAND_SZ /d "%%WINDIR%%\System32\SHELL32.DLL,130" /f
Reg add "HKCR\Directory\Background\shell\HideFileExt\Command" /ve /t  REG_EXPAND_SZ /d "wscript.exe \"%%WINDIR%%\System32\HideFileExt.vbs\"" /f
Exit
:IsAdmin
Reg.exe query "HKU\S-1-5-19\Environment"
If Not %ERRORLEVEL% EQU 0 (
Cls & Echo You must have administrator rights to continue ...
Pause & Exit
Cls
goto:eof
 楼主| 发表于 2025-3-22 12:27 | 显示全部楼层
@Echo Off
call :IsAdmin
echo     WSHShell.RegWrite "HKCR\Directory\Background\shell\HideFileExt\MuiVerb", "显示文件及扩展名","REG_EXPAND_SZ">>%HideFileExt%
echo     WSHShell.RegWrite "HKCR\Directory\Background\shell\HideFileExt\MuiVerb", "隐藏文件及扩展名","REG_EXPAND_SZ">>%HideFileExt%
rem 设置HKEY_CLASSES_ROOT\Directory\Background\shell子健权限
echo HKEY_CLASSES_ROOT\Directory\Background\shell [1 7 17]>%temp%\yj.ini
regini "%temp%\yj.ini"
Exit
:IsAdmin
Pause & Exit
Cls
goto:eof
GMT+8, 2026-2-4 19:29 , Processed in 0.037774 second(s), 27 queries .
